YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Rolling Down Rear Window (https://www.yotatech.com/forums/f2/rolling-down-rear-window-15300/)
justinh Aug 6, 2003 07:53 AM
I may be mistaken but shouldn't i be able to roll down the rear window using my key on my 1997 limited? I don't have the alarm/keyless feature for some dumb reason but shouldn't i still be able to roll it down at the rear hatch with the key?
INsr5runner Aug 6, 2003 11:38 AM
you should be able to roll up the window when you lock your door from the tailgate. unlocking the tailgate should unroll your window.
if you are having problems, hold the key in one position (depending on if you are opening or closing the window) for about 4 seconds. It should work.
hillbilly Aug 6, 2003 11:47 AM
One thing I noticed...
If you have your 'window lock' on, the rear window (and of course, any other window except the drivers) will not open using the dash up/down button. Don't think this would effect you using the key on the exterior switch, but it might be worth a look?!?
turboale Aug 6, 2003 12:01 PM
INs is correct. Its like the new VW add, you have to hold it in the unlock-down, lock-up position for .5 sec-1 sec for the window to start to move.
