Roll Bar and custom tire mount
http://s139.photobucket.com/albums/q...um/Roll%20Bar/
These are the pics of my Roll Bar install and the custom tire mount I made for the roll bar that is fully adjustable for any tire size. I have had it in a few weeks now and I love it tire doesn't move one bit and everything looks real clean. Let me know what you think.:welder: http://i139.photobucket.com/albums/q...r/IM000402.jpg |
looks good
Pretty slick with the Tire Carrier. I like it. Looks real clean. Good Work.
Looks good.
I'd consider putting some reinforcing plates on the underside the same size as the mounting plates on the roll bar. :guitar: |
I second the plates or at the very least some much bigger washers.
Extremely clean install though. Very nice. Also diggin the tire mount that you came up with. Mine is just ratchet straped to the boxed metal plates towards the bottom of the forward legs. Nice Job! |
Originally Posted by waskillywabbit
(Post 50370258)
Looks good.
Looks nice!!
Can't wait to get one of my own... |
Originally Posted by ADH8796
(Post 50370393)
Yes I agree with the plates or washers. I have already gone ahead and put much bigger washers on those are actually pics from the first time I bolted it up. The washers are not to big that they overlap but big enough that they almost touch I figure this should work just fine.
Not trying to toot my own horn, but I got a pattern that I made for reinforcement plates when I fabbed up Rock Slide's roll bar and I'd be happy to make you some if you are interested. It is a nice clean install, but I just don't think washers will get the job done in the long run. If you didn't have that spare tire on there, no problem, but I think that added weight will fatigue that sheet metal if you wheel it like that. If you are a mall crawler...no sweat. :hillbill: EDIT: Please see my other post below for clarification. :guitar: |
Originally Posted by sschaefer3
(Post 50370567)
If the plates are the exact same shape as the roll bar plates, the floor can shear. I make different shaped and larger plates. This would only happen in a real roll with alot of force.
:guitar: |
What tubing is the 1st Gen rollbar made of (OD & wall)?
Originally Posted by Cebby
(Post 50370588)
:guitar: |
Thanks Wabbit!!
I think if we consider that the 3rd gen 4Runner's body in stock form will easily withstand a slow speed roll over without crushing, then the roll bar will only help. Even if only just a little bit.
I don't think any of us are doing this for roll over safety though. Just like Wabbit said it is simply a mounting point for stuff. That it is from the 1st gen Runner makes it that much cooler. The 1st gen got all this started. It doesn't seem like the roll bar is supporting any of the spare's weight so the fatigue seems minimal. |
Originally Posted by ecchamberlin
(Post 50370603)
Again, if wheeling it will be more of a factor, if on-road use only, I wouldn't worry about it at all. :guitar: |
Thanks for the posts guys I'll consider building some plates but will probably just wait a while and see how the washers affect the sheet metal.
Nice pics.
My buddy actually Rolled his 4runner 3 1/2 times at 55 mph and walked away no problems. His 4runner is still driving around today the rear and the front of the roof were dented in a little here and there but the body shop just pushed it out the best they could and he has a 4runner that runs and drives and doesn't look to bad unless you get real close lol. I'll just say I'm still happy to have my roll bar even though I don't plan on ever rolling my 4runner.
(Post 50370603)
Not sure if this is what you are refering to or not but it would take a lot of substantiating information to explain what is being seen in those pics. Reguardless, Cool mod and keep us posted on what you come up with. |
