Reverse light Relays??
Old Mar 21, 2005 | 03:34 PM
SKO450ES's Avatar
Guest
Do alot of you guys have them on your rigs?? Because I was planning on installing them on to my 96 runner and wanted to know what type of relay to purchase if any. I would like to run the switch up front and not directly to my reverse lights. Do most of these light come with relays ??
Old Mar 21, 2005 | 03:35 PM
Localmotion's Avatar
You can go to RadioShack and pick up a relay....i think they are 6 bucks there. Most lights Id say come with relays. All my Hellas and my Piaas came with relays
Matt
Old Mar 21, 2005 | 04:19 PM
wiseguymmiv's Avatar
For my reverse lights, I bought a 30 amp relay at Autozone for $3 and some change. For $12.86, I picked up a factory fog lights switch from the dealership to run them. They work great! Get a relay so you don't have to worry about a short and possible fire. Also, use fuses between the relay and the power source (in my case, the battery). 30 amp fuses work well in my system.
Attached Thumbnails Reverse light Relays??-lights1.jpg   Reverse light Relays??-lights23.jpg
Old Mar 22, 2005 | 02:05 PM
SKO450ES's Avatar
Guest
Thanks dudes for your help....
Old Mar 22, 2005 | 02:18 PM
Tacoma Dude's Avatar
Check out Corey's write up in the tech section. That's pretty much what I went by:
https://www.yotatech.com/~corey/tech...ghts/corey.htm
...and this is my end result:
Here are some interior shots of my switch:
I keep the switch there because it's discreet and I don't have to worry about someone else messing with it. I also decided to go with the missle-launch type of switch so I know I'll never be driving with it accidentally on.
AkitaDog
Sep 1, 2015 08:05 AM
rchavis
Jul 27, 2015 07:41 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
colinmil
Jul 6, 2015 04:03 PM
