rear sags on '98 4runner
Old Jul 21, 2004 | 02:11 AM
anthraciterunner's Avatar
AFter I replaced all my shocks with Bilsteins, the front appears to sit a bit higher. IT seemed quite level before the swap but now it looks kinda like I got lifted in the front. Will this eventually settle out or should I start looking for rear springs? I haven't measured but the difference in the distance between the top of the tire and fender is about 1.5 - 2 inches. Has anyone else experienced this after changing to bilsteins?
Old Jul 21, 2004 | 02:17 AM
Bigkahuna808's Avatar
Mine had some very bad sag untill I replace my OEM springs with Downey
Old Jul 21, 2004 | 02:59 AM
I thougt saggy rears were only effecting mostly 96's. Guess not. How much are OME rear springs roughly? Cheaper or more expensive than new 3rd gen rear springs?-thanks
Old Jul 21, 2004 | 04:19 AM
WT's Avatar
WT
I did this a long time ago but are you 100% sure you didn't get the Adapter (Silver Aluminuim looking thing at the bottom of the spring) upside down when you put the shock back into the spring assemby ? That would add about 1 or so inches to the front. Plus my 96 always had a slight rear sagg too, till I lifted it.
Old Jul 21, 2004 | 04:54 AM
SLC Punk's Avatar
My rear end kept bottoming out when I had people in the rear seat. Its all fixed now with the pp springs!
Old Jul 21, 2004 | 05:41 AM
rimpainter.com's Avatar
I got a very slight lift in the rear when I went to Bilsteins...so it is possible. But your spring is more likely the culprit. It should settle over time a bit.
Old Jul 9, 2009 | 04:24 PM
thacarter's Avatar
back end questions....
i thought i was making a new thread
Jun 1, 2021 01:51 PM
Jdgarrison
Oct 1, 2015 05:22 PM
icentropy
Jul 11, 2015 07:21 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
