Rear end axle differential diff ujoint noise
1 Attachment(s)
Loud roaring / grinding on acceleration only.... Noise from the rear axle back story>>> I recently purchased a broken 1996 Tacoma Extra Cab 4-wd (175K). Attachment 122571 After repairing the left knuckle / tie rod / CV / brake line / strut from associated damage (ball joint failure / bolts backed out), I then was able to take my first drive. Immediately I noticed that the rear end was howling VERY loud (cant drown it out with the stock radio kind of loud). So is it bad ring and pinion or U-joint... ??? I pulled the drive shaft and it looked dry, not greased, but not too bad. Rear pinion has a beard of fresh gear oil, never a good sign, but usually just a plugged rear axle vent causing pressurization / relief (as the axle heats up) through the pinion seal. Both rear end and drive shaft look abused / no service. Back lash is a little excessive but not uncommon for 175K. Pinion bearing stilll feels tight. Later a second inspection of the drive shaft revealed the rearmost joint at the axle was a little stiff and might have a slight bit of play (neither are good). New Moog super duty U-joint is only $25. Koyo / Matsuba are the preferd brand ~ but at 8pm Friday night Moog will do just fine. I pulled the old joint down to find this.... V V V V V V V V V V V Looks like the needles got dry and began to wear. The diminished size turned them sideways slightly and they then became more of a bushing than a bearing. Ribbed / 30 spline U-joints are bad. This noise could have been amplified by the drive shaft tube mimicking a bad gear set. Will find out tonight if this was the only issue. https://cimg6.ibsrv.net/gimg/www.yot...b2b8293194.jpg Rocking everyone's favorite The infamous Trail Master 6" suspension lift. http://i9.photobucket.com/albums/a53...15_161201.jpeg |
Noise is gone! The roaring / grinding on acceleration was the rear u-joint.
Further inspection of pinion with drive shaft installed reveals that it does have slight lateral play. This will need to be addressed but so far it is not a deal breaker. Hope to measure it soon with a mag base dial indicator to quantify the number. |
