Re-Torquing Drive Shaft Flange Bolts
Depending your maintenance interval 5k or 7k, toyota recomends to retorque your drive shaft flange bolts to spec. Is that really needed, if you never taken your drive shaft off because those bolts have factory lock tight on them.
The only way to get a torque wrecnch in there is with a extension and universal joint. So who here does this? |
Not me, but I can tell you that those are on there REALLY tight. I had a tough time removing mine.
