Radio Security Code
I have a 94 Runner. Had timing belt replaced and my factory installed AM/FM Tape radio went into security mode. I have two tries remaining to enter the proper 3 digit code. Does anyone know if there is an over-ride code or how I can find a code to make the radio operable? I have the owner's manual, VIN etc. The dealer will corrent the problem for a 1 hour minimum (could be longer) visit but I'm not going to pay them because they created the problem. Any help would be greatly appreciated.
Paul in Maine |
The Stealer is the only way to unlock the code if you don't know the cade that came with the rig when it was new. I had to pay $40 to get the wifes unlocked after swappin' batteries. RIP OFF!
If the Stealer did the timing chain work and that's the reason for the battery being disconnected/lock enabled, they're responsible for unlockin' the stereo. |
Mine did this too, and I actually tried 10 times and locked it out. I took it to a stealer and said that a rep at 1800-go-Toyota said they would do it as a courtesy becaue it's so common. Pull that crap with the dealer, I'm sure they'll do it for free.
:D |
:D |
| All times are GMT -8. The time now is 04:03 AM. |
