YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Radio replacement (https://www.yotatech.com/forums/f2/radio-replacement-166813/)
Dianna Feb 12, 2009 06:35 AM
Radio replacement
Walmart has 2 different radios on clearance and I'm looking to replace my factory radio in my 4Runner since the backlight in the display has started intermittently coming on and off. I'm wondering if either one of these is worth buying for the price:
Pioneer DEH-P5900IB for $124
http://www.pioneerelectronics.com/PU...rs/DEH-P5900IB
or Sony CDX-GT50W for $99
http://www.onlinecarstereo.com/CarAu...roductID=17391
If not, any recommendations? Thanks!
Dianna
bipolarandproud Feb 12, 2009 07:03 AM
Can't see the Radios the links don't take you to the right place I guess.
Repost the links if you can! I think Pioneer and Sony are both good brands names tho .
97ltd4x4 Feb 12, 2009 08:03 AM
You could look into buying a used scion radio(pioneer) on ebay.My CD was messing up and I found one cheap.Needs very little to modify to install(bracket and slight center console cutting(inside)),plug and play w/4runner harness,it bypasses the factory amp.The coolest thing is it can play MP3 discs,and some have a plug in the back and with a cable can hook directly to MP3 player...And it sounds way way better than the factory unit in Xb mode.
Motayota Feb 12, 2009 08:49 AM
Both of the units mentioned need no modification what so ever. I would stick to ordering something off of Crutchfield, that way you know it fits and they send you the brackets and harness you need, plus install instructions and support if you run into problems.
Here are a couple that are simple:
Sony-Simple and $79.99
http://www.crutchfield.com/p_158GT13...0.html?tp=5684
Kenwood.$99.99..plays MP3/WMA Aux-in in the front for any MP3 player.
http://www.crutchfield.com/p_113MP14...2.html?tp=5684
Pioneer $99.99 same features as the Kenwood.
http://www.crutchfield.com/p_1301100...P.html?tp=5684
JVC $119.99...this has the most bang for the buck...plays MP3/WMA disks, front Aux-in, Built in HD Radio Tuner, optional Ipod control w/optional cable.
http://www.crutchfield.com/p_105KDHD...0.html?tp=5684
Lot of stuff out there, the models listed in the first post are discontinued models.
SoCalPaul Feb 12, 2009 11:45 PM
I have a Pioneer Premier 790 BT. Installation is simple. Use the stock brackets & get a wiring harness kit, It is almost plug & play. The Pioneer sounds great, but the buttons are pretty small. I don't know why so many aftermarket radios have small buttons. Fortunately mine came with a remote.
http://www.pioneerelectronics.com/PU...ers/DEH-P790BT
Paul
Elton Feb 12, 2009 11:50 PM
i like pioneer my self
98.T4R Feb 13, 2009 11:29 AM
defiantly go with the 5900ib for the price that is amazing. i have ben an installer for 3 years and have been very satisfied with the pioneer but not so much luck with the sony's in the long run. that model of pioneer has lots of options for ipods and other mp3's. the sony has trouble playing mp3 players other than ipods.
psraff Feb 13, 2009 12:11 PM
That's what I did and I'm happy with it.
ricky Feb 13, 2009 01:20 PM
I, personally, would never buy another Sony car stereo. Home stereo on the other hand...
flashkl Feb 13, 2009 02:24 PM
I replaced my alpine unit with a sony that's very similar in faceplate design to the one in the original post. My sony is amazing...I havent owned a pioneer so I can't judge, but if the internals of the one above is anything like whats in mine, the sony will sounds much better than stock.
littlecommando Feb 13, 2009 02:28 PM
go to brandsmart usa, i got my hd radio there for $100
pyro29073 Feb 13, 2009 02:31 PM
go to wal-mart and mess with both of them and see which one is easier to work for you, ive heard good and bad about both, but to me a radio should be easy to work while driving
littlecommando Feb 13, 2009 06:34 PM
well, you really shouldnt mess with your radio while driving anyways.
pyro29073 Feb 13, 2009 06:40 PM
well you may not but i do, whether it be switching between stations or w/e
