YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Radio Help... (https://www.yotatech.com/forums/f2/radio-help-138038/)
crdean1 Feb 20, 2008 08:39 PM
Radio Help...
I am a new member and I appreciate all of the help this forum has been in the research of my new 4Runner (1999 4x2, black, sport). Tonight I changed over to synthetic oil (mobil 1). Learned that the filter is in a crazy spot, and got oil all over my garage. Much fun. Tomorrow night, I am going to install an Alpine Head Unit and remove my double din factory unit.
I haven't ever done an installation, but I am using the write up provided on this site as somewhat of a guide. One question, the guys that sold me the tray, ipod cable, harness/ kit told me that I needed to run a cable to the battery for this HU because it is a V-Power, whatever that means.
Can I just run that cable with the rest of the fuse cables through the firewall and attach it to the positive battery connection, or do I need to drill a hole in my firewall (which I don't want to do) and cover the wire with some rubber or something????
The rest of the install looks fairly easy, this is the only part that is concerning me.
Thanks in advance for your help.
Scooby098 Feb 20, 2008 08:50 PM
just run it through ur rubber gromet wire the rest of ur wireing harness goes .
olharleyman Feb 20, 2008 08:57 PM
x2 my stereo , cb , amp , and 8 kc lights wiring fit thru there with no problems and no extra coating on the wires where needed.
fullmann Feb 21, 2008 09:38 PM
alpine told us all in training that we needed to wire the yellow battery wire direct on those decks as well. at first we did, then to the ignition harness using a T-tap.
now....we just wire em into the harness just like any other deck. I've yet to run into a problem with that method. I have trouble believing that they can reliably squeeze 65 watts out of an amplifier that small, and still only need a 16ga input power.
crdean1 Feb 22, 2008 05:34 AM
Well, I hooked it all up last night. It was quite an experience, but I learned a lot and my truck is still in one piece. It fits nicely, and I just poked a small hole in the rubber grommit (sp?) that feeds my wire harness through the firewall and used that small hole for the wire to the battery.
Then I put a fuse about 2 inches off the battery to be on the safe side. Everything works well for now, and it even sounds awesome with my factory speakers, which sounded like total crap with the factory HU.
Thanks so much for your help. I'm sure I'll be installing a sub or two in the coming weeks, much more to learn.
cackalak han Feb 22, 2008 07:29 AM
If you don't want that factory HU, I'll take it off of your hands. :D
Speedy Feb 22, 2008 08:22 AM
I've got what you need:
https://www.yotatech.com/forums/f109...eo-amp-137892/
cackalak han Feb 22, 2008 08:53 AM
Originally Posted by Speedy (Post 50758770)
I meant I'd take it off his hands for FREE. :hillbill: Mine works perfect, but just wanted to get a spare one incase it goes out.
Speedy Feb 22, 2008 11:47 AM
You can still have a spare.....I think you REALLY need it...you just never know :D
crdean1 Feb 25, 2008 07:28 AM
Thanks for the offer but I'm going to keep it for if/when I ever sell the truck. If someone absolutely needs one, I'd consider selling it to help them out if they couldn't find one, but I'd prefer to hold on to it.
