quick SAS question
so this might be a dumb question but i was wondering if i could use the same brakes and calipers from IFS setup on a straight axle (most likely a dana44) and would i loose the ABS?
You want to use the IFS brake parts on the factory toyota front axle, not the Dana44. The brakes on the Dana axles are already vented and just as large
Isn't the Taco gonna be a DS drop differential and gonna need to use the Dana axle anyway? Won't be able to use a Toy axle AFAIK.
| All times are GMT -8. The time now is 07:17 AM. |
