a quick elocker question
I have a 2000 runner with the factory e locker, what i'm wondering is I bought amzoil they recommended severe gear 75w-90, because I tow now and again, the amzoil guy wasn't sure and neither am I if that diff is limited slip or not , that is my question..
it says on the bottle " if limited slip chatter occurs use amzoil slip-lock" just wondering if its fine to use thanks |
e-lockers are not limited-slip. when activated, they are no-slip.
Originally Posted by irab88
(Post 51939500)
so the Amzoil should be fine then with no chatter probs then? again thanks for the help |
yeah, completely open until you lock it. no "limited slip" stuff
(Post 51939571)
yeah, completely open until you lock it. No "limited slip" stuff
toyota rear diffs take 80w90 gear lube, not 75w90, get some 80w90
FYI....it is e-locker not e-limted slip.....it mechanically locks both axles together when u push the button.
| All times are GMT -8. The time now is 02:51 AM. |
