YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Power Brake Booster (https://www.yotatech.com/forums/f2/power-brake-booster-28488/)
The Nak Mar 10, 2004 11:26 AM
Power Brake Booster
The brake booster on my 88 4Runner is whistling at me everytime I stop, so I assume it has a hole in the diaphram. Does anyone have a suggestion/opinion on what I should replace it with? Is there a good aftermarket piece that someone could recommend? How about whatever Pep Boys might carry? Or is the best, and probably most expensive solution, to buy a new one from the local stealership? Any suggestions are greatly appreciated.
Nak
Mohamed Mar 10, 2004 12:04 PM
Those things usually last the lifetime of the car. Is it possible you have a hose leak rather than a hole in the diaphram? My personal opinion is pick one up from the junkyard. They are usually in fairly well condition.
The Nak Mar 10, 2004 12:15 PM
I've always thought they were good for the life of a vehicle also. I don't know of any hose or anything else associated with the brakes that would cause this whistle. It only whistles at a certain pressure (about 1/4 till 3/4 of the pedal depressed), I had someone push the pedal while I listened, and it certainly seems to be coming from the booster.
Thanks
Nak
Yoda Mar 10, 2004 12:48 PM
1/4 million miles! No wonder its wore out.
It does seem to be the booster. Just get one from a wrecking yard, of ask "Toyota parts dude" if he has one. He is on the members list.
