Pic of Edlbrock headers (coated & wrapped)
Old Apr 10, 2003 | 07:18 AM
Zubaltec's Avatar
Port matched, HPC coated, Thermotec wrapped & sprayed, and still cheaper then TRD. We'll see what kind of power these babies put down.
Old Apr 10, 2003 | 07:34 AM
TDiddy's Avatar
The pic is a bit small, but lookin' good nonetheless!
Old Apr 10, 2003 | 08:11 AM
pfdaxe's Avatar
You made Edelbrocks fit your '99??
Edelbrock told me they didn't make them for '99+
Where did you get them and how much was everything??
Paul
Old Apr 10, 2003 | 08:55 AM
Los Gatos?'s Avatar
Did you tape them specifically so they would rot out in under 12 months, or was that just one of the many side benefits?
Old Apr 10, 2003 | 09:08 AM
rimpainter.com's Avatar
Taping headers wont cause them to rot. I taped my header on my 95 SI for 2 years without a problem, and that's when I lived in Seattle.
Not only does it increase the scavenging effects of the header, it also visibly (temp gauge) reduced the temperature under the hood.
You just have to make sure you do it correctly, or you will get hot spots.
Old Apr 10, 2003 | 09:20 AM
Dr. Zhivago's Avatar
Away
Yeah, header wrap is ths shiznit, if done correctly. I used it to wrap my turbo and it lowered the underhood temps by about 1,000,000 degrees. I used an Electron Scanning, Nuclear Powered Thermometer to measure that change.
Seriously, it does make a huge difference when done right. I'd like bigger pictures of them, Zubaltec. Please?
Paul, I think that if you have a factory single Cat, the Edelbrocks will fit any V6 4Runner from 1996-2000. Call Edelbrock to make sure.
Peace!
Dr. Z
Zubaltec's Avatar
Got the headers & wrap (Thermotec) from summitracing.com. I think it was $350 for the headers, about $100 for 2 rolls (2"-50ft) wrap, snap straps, 2 cans black silicon spray, and then the HPC coating (got a deal as they sponsor our race car). I've used wrap on my old Civic and just about every single turbo Supra I've done. It holds up well, you don't burn yourself, and I've proven it to help make more power. The only side effect is the smell of it for a week or so.
Old Apr 10, 2003 | 09:53 AM
pfdaxe's Avatar
Z:
Edelbrock states up to '97 on the 3.4L for some reason.
Old Apr 10, 2003 | 09:57 AM
Away
Paul, that recommendation probably has to do with the EGR/Emissions fittings, which could probably be plugged by a resourceful installer. I dunno, hopefully Zubaltec will enlighten us.
Peace!
Dr. Z
Old Apr 10, 2003 | 10:46 AM
LOL, can I see your spreadsheets for this data?
Hey I figured out where you got your username while I was watching Ronin last night.
Old Apr 10, 2003 | 11:33 AM
Zubaltec's Avatar
I cut the EGR flange off and welded up the hole. Well the exhaust just got here so, it looks like I'll be busy tonight. I'll report back later on what I think of both the headers and exhaust.
Old Apr 10, 2003 | 02:45 PM
FattyCBR's Avatar
Originally posted by pfdaxe
Z:
They fit fine on my 98, I had to make a block off plate for the EGR and if you have an auto you have to fudge the routing of the kickdown cable. It's literally no exaggeration to say that the directions are the worst I have ever seen, so if you get them you're pretty much on your own for install. Also reuse your stock manifold gaskets or buy new ones from Toyota the ones that come with it are the paper/asbestos type and I wish I hadn't used them.
Old Apr 11, 2003 | 07:47 AM
zedex's Avatar
Well.. I think DrZ should head out to Orlando and help out Zubaltec. And while hes there he can take pictures and do a decent write up on the install. Sound good?? Ok then.
Old Apr 11, 2003 | 08:05 AM
Zubaltec's Avatar
Well the install is done. I left the cat in for now. Waiting on another Borla muffler to replace it. I notice a little power increace. At 4000rpm you can really feel it. For everyone- These headers fit my 99 2WD auto. So now all of you can go out and buy them. Just block off the EGR. I have a couple EGR block off plates if anyone needs them. Well we have power back to the dyno so, I'll have results within the weekend.
Old Mar 25, 2005 | 05:38 AM
mt_goat's Avatar
Zubaltec, care to update this thread? I'd like to know how the wrap and headers are holding up after a few years now.
Anyone else tried wrapping their Toyota truck headers or have any expenence with how to correctly do it.
Old Mar 25, 2005 | 07:16 AM
HaveBlue's Avatar
I've had mine wrapped since February 2003. So far so good. No problems that I am aware of.
Old Mar 25, 2005 | 07:29 AM
mt_goat's Avatar
Cool, did you use the Thermotec wrap too? I saw on their web site not to overlap the wraps more that 1/4 inch, is that what you did? Any more tips? I'm guessing with the wrap you wouldn't need a lot of extra heat shielding, is that a correct assumption? What headers do you have?
Old Mar 26, 2005 | 12:41 PM
Zubaltec's Avatar
Still holding up strong.
John
Old Mar 27, 2005 | 03:37 AM
johnyrrr's Avatar
dyno info or times
Zub, have you ever had a chance to redyno your runner after the headers? Any better with the test pipe too?. I have a 02 with two cats, well only one really and would like to know if your milage got any better too? you were reporting 19mpg correct? did the install require any welding or was it a bolt on only job? Thanks alot
Corvoid
Sep 4, 2015 11:55 AM
Sep 4, 2015 09:27 AM
clok
Aug 1, 2015 09:42 PM
anniesball
Jul 29, 2015 11:46 AM
