parking brake
Anyone ever have the parking brake warning light stay on in their Tacoma?
I can push the parking brake lever in while driving and it briefly turns off, then comes back on again. Is there any way to adjust the linkage or lever so this does not occur? It's not really a huge issue, but it sometimes gets annoying. |
This sounds like its low brake fluid in the master cylinder not a linkage adjustment.
I had the same problem.
Go buy some brake fluid and fill your resivoir all the way to the tippy top, problem solved. |
Originally Posted by NwRunner
(Post 50818407)
Go buy some brake fluid and fill your resivoir all the way to the tippy top, problem solved. Find the problem first. There is a reason the brake fluid is low in the first place, be it from leaking, worn brakes, etc etc. Find/fix the problem first, THEN fill the reservoir. |
Originally Posted by DeathCougar
(Post 50818424)
Please do not just "fill it up" and forget about it.
instead of tearing into the car to find a possible problem as deathcougar suggested, fill your resivoir and watch the level. If it stays the same you are fine, as with my case. But if it drops again, then you should look into fixing some sort of brake problem.
| All times are GMT -8. The time now is 04:50 AM. |
