P0172........
been searching for a while, on my old 2000 4runner 5spd 4x4 supercharged with 7th inj, it just started to run rough here & there, seemed like it was mostly after it was warmed up, now idles low & chuggy, and surgy when accelerating & threw a p0172 - system to rich. From what ive found... the culprits for po172 seem to be:
MAF - already replaced dealer item Front 02 sensor - Replaced dealer item Injector leak/blockage Engine coolant temp sensor Fuel Pressure Gas leakage on exhaust system Heated oxygen sensor - bank 1 sensor 1 Ignition system So thought it might be a simple maf & 02 sensor, so i switched em out for dealer new ones for my vin#, left batt disconnected for an hour, hooked it up and drove for 50 miles....still same prob. I had my injectors cleaned by witchhunter about a year or so ago, and ive got the walbro 255 fuel pump in the tank due to the blower. Ive checked all the wiring to the pnp harness for the 7th inj, even unplugged it and just used the stock ecu, but still same prob. Plugs are clean, in fact new IK22's as of a month ago. Ive never heard of the FPR (fuel pressure regulator) go bad on these motors, but how do i check? Would the coolant temp sensor really make it run rich?, cant see how. Any input is appreciated. thx. |
Originally Posted by j-man
(Post 52042200)
On the 3.0, the FPR has I think 2 hoses, one return line and one vacuum line that goes into the intake. Find that hose that goes to the intake and pull it off the FPR and wait to see if fuel drips out. IF SO, your FPR is bad, causing your engine to flood. . Just remember to pull of the correct hose :)
sounds reasonable, where is the coolant temp sensor located?
Originally Posted by TheDurk
(Post 52042232)
When coolant temp sensor fails open (not uncommon), ECU thinks motor is cold when it's hot, thus going into open loop and forcing a rich mixture. Running better at start-up tends to say this IS your problem.
(Post 52042366)
http://tacoma.site40.net/4Runner_96-.../ects/insp.pdf |
Awesome, thx. Will break it down this weekend.
(Post 52042498)
well i put a new engine coolant temp sensor - the one for the EFI as pictured above, and no difference after battery reset and driving 50 miles. Maybe i can describe the prob better.
Now as i accelerate gently/normally (not wot) it chuggs then drives normal. It still feel like its fighting open/closed loop. Im completly stumped on this, and i usually figire things out pretty easily. Unless i give in and take it to the stealership...im at a loss & i dont have access to any live scan gauge. |
