YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   OME/ARB/Revtek?! (https://www.yotatech.com/forums/f2/ome-arb-revtek-33033/)
User 051420 May 19, 2004 07:12 PM
OME/ARB/Revtek?!
My Sahara bar may be getting here as soon as next week!
I KNOW that once it gets on, I'm gonna want more lift. My question is if I could add a revtek top out spacer to the 882's I have now? That would give me about .5" more, no? Could I go even higher?
CV's scare the CRAP out of me. As it is now my CV's are at a somewhat normal level, and I dont worry about them as much as I could.
In my situation with the lift, my control arms are actually tilted downwards (assumed normal with a lift). Does the top out spacer fix this to an extent? Or am I misunderstanding this?
User 051420 May 20, 2004 09:40 AM
Bumpity Bump Bump!
RTdawgs May 20, 2004 01:36 PM
you have 882s and no bumper and your CVs are at a fairly stock level? yea right!
the guys i know with 882s are getting 2.5" lift with ARB bumpers and winches.
turboale May 20, 2004 01:54 PM
Dude... you were getting the ARB to level out the cvs... remember?? ;)
User 051420 May 20, 2004 04:26 PM
The levels ARE pretty decent... Yes I know i'm getting the arb to level them out more, but I was thinking maybe it would level it more than enough and I could go back to pushing the limits? :laugh:
http://homepage.mac.com/gapisgreat/images/newcvs.jpg
They've settled quite a bit more level after the 1k miles I've put on the lift.
RTdawgs May 20, 2004 05:46 PM
the 882s will not sag much with only a bumper.
IMO, those CV angles are too much.
User 051420 May 20, 2004 07:45 PM
Hmm.. I'm glad to hear they won't sag that much. The CV's have settled down a bit after the 1k miles and an allignment. Those pics were IMMEDIATELY after the lift.
We'll see about all of this though.
Anybody know more about the Revtek Top Out?
RTdawgs May 20, 2004 07:47 PM
i have one...what you need to know?
User 051420 May 20, 2004 07:52 PM
You have one, so theoreticly I could also run one once I get the bumper?
I'm just curious because I'm a bit "nose down" right now, and I'm afraid it'll only go farther.
RTdawgs May 20, 2004 07:59 PM
you can add a revtek topout spacer to your OME coils.
if i was in your shoes, i would install your bumper, drive about 5000 miles, decide if you want more lift, determine amount of desired increase, select a spacer or other option from there.
User 051420 May 20, 2004 08:02 PM
Thanks for the advise. I knew it could be done, but not sure it was safe with the bumper.
5k miles shouldn't be bad as i'm going on a 2k road trip to WY next weekend..and hopefully my bumper should be here next week.
