YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   ? New intake ? (https://www.yotatech.com/forums/f2/new-intake-37793/)
YotaTruck1986 Jul 31, 2004 03:56 PM
? New intake ?
Ok, it seems that the intake on my truck is being monitored by the air flow sensor and ECU. What would happen if I replaced it with a universal intake that consists of just a pipe and filter? The pipe runs straight to the throttle intake and the other end has the filter on it. What would happen? Thanks.
humanoid Jul 31, 2004 03:59 PM
Without the ECU, MAF or AFM your engine would run lean or rich and also may encounter a host of other problems.
YotaTruck1986 Jul 31, 2004 05:27 PM
Well how do i install a new intake system? Like a blower?
jimbo74 Jul 31, 2004 05:29 PM
a blower will have its own system
YotaTruck1986 Jul 31, 2004 05:45 PM
So im out of luck for creating my own?
bktaco Jul 31, 2004 09:07 PM
i dont know about your 86, but my 2.7L doesnt run without the MAF. I bumped it off once when i was wrenching, and the engine killed. i think the ecu needs an airflow signal at least.
jimbo74 Jul 31, 2004 09:18 PM
what are you doing? are you talking about making a chromed tube or something? a s/c will have all its own intake plumbing with a built in provision for the sensor... as will an aftermarket intake system.. if you are making you just need to reuse the sensor....
