My Fogs are Dead
I've got power to the switch and I can hear the relay clicking, but no lights. Just happened out of the blue. Both bulbs appear good and the harness is hooked together well. I'm bummed :baby:
Any ideas as the to the problem would be helpful. Thanks folks! |
Any ideas as the to the problem would be helpful. Thanks folks! Matt |
Sudden death
Sudden death usually means one of two things:
1) blew a fuse somewhere (don't forget ones that may be in-line as well as in a fuse box) 2) bad connection, usually a ground wire If they are Hellas or aftermarket, check the connectors coming off the relay as they have a tendency to wiggle loose and then electrical tape them up to the relay so thye are sturdier. Good luck! :guitar: |
Could be a relay too.
See this post by me. I had to test a relay, and I found out it was bad. Replaced it and all was bliss. |
