My 3vze is HISSING at me!! (PT 2)
Old 05-26-2005, 08:29 PM
Bumpin' Yota's Avatar
My 3vze is HISSING at me!! (PT 2 - DO NOT MOVE)
DO NOT MOVE THIS POST!!
No there are no snakes under my hood! LOL
But with the engine idling I hear a hissing sound from the front passenger side head emmenating from the front edge of the head. I can localize it to about a 12" radius area but I can't figure out where it's coming from.
Before I pulled my plenum and reshimed my valves, I thought it was the valve cover leaking....But with 100% non leaking valve covers, new PCV valve and PCV mod it's still there...
Any ideas? The truck idles fine...
259,931 miles at present...:d
Old 05-26-2005, 10:23 PM
Alin10123's Avatar
Do you have a supercharger on there? sometimes the supercharger will have a little more air intake noise.
Old 05-26-2005, 10:58 PM
Praufet's Avatar
Please tell me you just didn't say that. No one makes a supercharger for the 3.0. Also that would be a pretty obvious thing. Also all the intake stuff is on the drivers side.
Old 05-26-2005, 10:59 PM
DudeBud's Avatar
you sure its not a vacume leak
Old 05-27-2005, 04:51 AM
(I wish my 3.slow had forced induction...lol)
Yeah, I am 99% sure that it's not a vacuum leack. I recently pulled the intake plenum and made sure that every hose was accounted for and in place. Its not the valve covers or PCV valve... If an exhaust manifold were leaking it would be a pulsating hiss and not a continuous his like I have?
Old 05-27-2005, 05:10 AM
dragon564's Avatar
From my exp. I always thought that exh leaks under hood were accompanied with more valve train noise as also.....frnt pass side I think the reed valve and EGR are just behind that area and that would be right around the area of the P/S pump. Front side start into the timing belt area. Not be a smart butt here...you sure it is an air hiss and not a belt or bearing whine that you are hearing. Does it change with RPMs or is it constant?
Old 05-27-2005, 05:19 AM
HondaTec521's Avatar
Maybe it's just inner ear damage ( 159.8 db @ 42 hz )
Old 05-27-2005, 05:20 AM
yes, the reed valve is towards the back of that same cyinlder bank, but the EGR and EGR modulator are right there next to the PS Pump...
I thought that both belt whine and bearing whine would be a squealing noise? I haven't tried listening at different RPMs. I'll do that today.
Old 05-27-2005, 05:49 AM
PirateFins's Avatar
Take pic of the area you think it is comming from. Somebody might be able to look at it and give you some things to check.
Old 05-27-2005, 08:45 AM
idotmyi's Avatar
try getting a piece of old tube, I use a garden hose, and using it like a stethescope (sp) just put it up to your ear and move that bad boy around the engine bay till the noise is the loudest.
Old 05-27-2005, 02:10 PM
LOL, nope I am not one of those idiots you hear bumping down the road. In fact very few people even know that a system of any kind lies behind the 5% tint....
I do have minimal ear damage however.
Steve
Old 05-28-2005, 12:53 PM
89macrunner's Avatar
Steve
header gasket??? that might be it...anyways i would imagine you have hearing damange...120db is harmful to the human ear...159.8 db...well...self explnaitory
Old 05-28-2005, 05:17 PM
SD70MAC's Avatar
Does the engine idle rougher/lower than normal? A few months back, my idle dropped and the engine was running a little rough. I could also hear a hissing sound from under the hood. Turns out it was a PS vacuum hose that had dry-rotted and finally broken. There are like 500 little vac lines around that PCV.
Old 05-29-2005, 06:12 AM
YotaJunky's Avatar
I've also got a hissing sound that seems to be coming from the passenger's side and I can't figure it out either. I haven't lost any fuel economy, but have noticed that the engine is vibrating a little more during idle than it did before the hissing sound started.
Troy
Old 05-30-2005, 07:18 PM
AgRunner06's Avatar
My vote is for a vacuum leak. BTW there is no way leaking valve covers are going to hiss...
MadMax48
03-03-2020 10:33 AM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: My 3vze is HISSING at me!! (PT 2)
