Mounting Turn Siginals in the Marker Lights?
I want to Mount my Turn Siginals in the Marker Lights. I'm looking for the How-To. Yes, I searched but I didn't find anything. There is only one page in the electrical how-to now. What happened? It looks like alot of thread pages have disapeared. Anyway back to my question. Does anyone have the How-To?
i am doing the same thing tonight actually!!! my roommate is helping me (he did it to his) i'll tell ya the how to tonight or tomorrow morning on here and a pm!!!
I recently did this for my 4runner. When I installed my new bumper.
http://i150.photobucket.com/albums/s...r/IMG_2671.jpg When i did mine, i basically went down to autozone and and got some bulbs and bulb housings. When pulled out my marker lights, pulled out the drain hole drilled a hole the size of the new bulb housing. Siliconed the new housing in with the new bulb, so i can remove it easily. Then cut the old turn signal lines and attached them to the bulb housing. One thing i learned is that you need a higher watt bulb, in your new turn signal bulb. I started off with a 4 watt bulb, and and my turn signals would flash really fast like one of them was out, but it all worked. I am now using 18watt bulbs and everything works great. |
here you go:
http://www.customtacos.com/tech/index.php?article=91 |
Thanks for the info. That is pretty much what I figured.
Crolison, Your bumper has inspired me to build myself one. Somewhat like yours. That is why I need to move my turn siginals. I think I'm going to fab up some mounts for my stock fogs. |
Originally Posted by Gerdo
(Post 50643250)
Crolison, Your bumper has inspired me to build myself one. Somewhat like yours. That is why I need to move my turn siginals. I think I'm going to fab up some mounts for my stock fogs. That would be cool to use your stock fog lamps. I think i am going to get some small 3ish" round fog lights, and put them in the speed holes on the bottom. |
Originally Posted by Whitey13
(Post 50643227)
here you go:
http://www.customtacos.com/tech/index.php?article=91 another way would be to simply switch around the wiring for the corner lights/bumper lights each becoming the other. I may try the link way though it looks pretty sweet... aviator edit: on further review there may be another way... I'll rsearch and post back |
Originally Posted by aviator
(Post 50643279)
I will pop out one of my markers and get some pics and post them up here tomorrow. |
heres a better write up http://www.lieblweb.com/tacoma/Mecha...n/blinker.html
I did a little more thinking on this mod and the 1157 bulb would be HUGE inside the corner housing, it would probably be better to use one of those 1157 LED set-ups if you do this mod. Longer lasting too :D ...
I'm still thinking on a better way to do this... edit: thanks crolison and elton |
http://i150.photobucket.com/albums/s...r/IMG_2674.jpg
http://i150.photobucket.com/albums/s...r/IMG_2673.jpg Thats how mine are, and it works nicely. |
Looks like you got your turn signals in the factory location there crolison
yeah i do, originally we had them at the bottom and when you used the turn signal everything would work, but it would flash really fast. So we tried switching to use the running lights, then they still flashed really fast. So it took a higher watt bulb to have enough resistance to stop the fast flashing.
