Long cranking when warm?
Old Jun 9, 2019 | 05:12 AM
bensyota's Avatar
Originally Posted by aowRS
^ No more long-cranking issues since installing the new Toyota fuel pump earlier in May. I’ve put a few thousand miles on it already. Good luck getting yours figured out.
Andreas
So your saying the coil didn’t solve your long start problem and that the fuel pump did? I thought when you replaced the coil it fixed the issue and then your pump just went bad on you? Just wondering because I have the warm start issue. I just checked resistance of my secondary coil when the issue occurred and it was ohming out at like 25.k and slowly when down. Spec reading is 11.-18. When warm.
1990mudslut
Aug 21, 2010 04:26 PM
climber87
Sep 21, 2009 03:57 PM
dutchboy
Nov 25, 2008 09:05 PM
chrisbnaz
Sep 1, 2008 12:35 PM
khany2002
Jun 3, 2008 07:48 PM
