Originally Posted by jrallan26
Looks awesome! Great job on the wheels! Any rubbing or any adverse effect with the bump up on the wheel upgrade?
And now with a little more driving and my commute, I can say for me the rear set up is spot on perfect and the front is darn close..it may have ben binding some as its worked itself out but now feels very smooth... It feels better than it did even Friday. Clearly the best 3rd gen set up I hve had to date.. I may even try OME comfort shocks up front at some point with the TRD springs. David |
Originally Posted by unr.frosh
You inspired me, I pulled the trigger on 4WD tundra springs and N91s struts up front. Extended studs and 2 pairs of spacers to make her level. Still deciding on the rear. Might keep what I already have, but it's pretty bumpy, I'll see how it feels/looks with my new front.
I hear this a lot about the stiff ride of the SAWs. I got a tip from Rob2k to take the saws down to 2.0 inches and then put an Andy spacer on top with some longer 9/16" bolts from Home Depot. I contacted Andy to see if this was cool and he said no problem. It really worked. By taking lift out of the Saws it softens the ride a lot. Sorry for the thread high jack |
The LC rims look very cool. Mine will need to be refinished some day also. I am trashing them off road.
Very cool looking rig! |
i like the color.
Originally Posted by KyleT
i like the color.
David |
I have a line on some used struts from a double cab 04' TRD 4x4, just to confirm these are the right ones correct?
Here they are: http://www.adldesigns.com/toy/DSCN1023.gif |
those shocks and springs look like the ones i put on mine, i used new though, they are from a tundra correct? taco ones wont lift it any IIRC.
That's the front end assemply from a 04' Double cab Taco 4x4. I am only going to use the tokico struts from it, and I will use the springs from a tundra...
What year tundra springs work? I know I want the TRD springs from a 4x4 or a 4x2 because they are progressive, but what years are the ones I want? Thanks |
Originally Posted by nrgetic99
In case we forget, a moments silence for our fallen friend who inspired my new project..I still prefer the looks of my sadly expired 93..
http://pics.montypics.com/nrgetic99/..._93r_poser.jpg David David, I was curious what type of rims were on your 93? Thanks in advance. |
Originally Posted by CDUFF7
(Post 971035)
Thanks in advance. AR23's in a 15 x 8 with a 3 3/4 backspace. They quit making them... David |
