YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Leveling out 95 4runner (https://www.yotatech.com/forums/f2/leveling-out-95-4runner-19681/)
chrisitobandito Oct 22, 2003 03:08 PM
im raising the back of my moms 95 4runner by swaping in new springs. is there any special tools i need to do this? ie coil compressor. thanks
doink Oct 22, 2003 04:07 PM
ive heard that to put in new coils, you dont need a coil compressor.when i put spacers on my rig on top of my coils, i used a set of external coil spacers.
Flygtenstein Oct 22, 2003 04:12 PM
With stockers, you should be able to pop them out sans compressor.
Support the frame on stands, take off the wheels, disconnect the shocks and have at it.
Robinhood150 Oct 22, 2003 04:24 PM
Also disconnect the sway bar and watch the hoses (brakelines etc) that attach to the axle, you might want to loosen some of these up. You don't want to rip these out. There are a couple writeups in the tech section on how to swap out the coils.
szf2 Oct 22, 2003 04:27 PM
When I put some new Downey coils on my 95 4runner, the stock springs came off no problem. Disconnect the shock absorber (at least on the bottom) and dissconnect the swabary in both wheel wells (2 bolts per side). Then jack up the vehicle, support it on the frame. After that, I CAREFULLY pushed down the axle housing with my foot and the stock spring came out no problem.
For putting in the new spring, I used a $9 spring compressor from Harbor Freight. Not sure if I needed it or not. I bought it for the job so I used it. However, the Downey coils were the same height as stock springs (more or less) just with 1 extra coil for more support. So, I probably could have gotten the Downey's in w/o the compressor.
Here's alink to my Downey Coil writeup that has some pictures showing the different springs.
