YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   LC Engineering Header? (https://www.yotatech.com/forums/f2/lc-engineering-header-72269/)
90FFyota Nov 21, 2005 08:43 PM
Hi all, I had a question regarding a lc header for my 1990 pickup 4x4 reg cab with a 22RE. On lc's web site the only application I can find is a header for a 22R, will this header work with the 22RE? Thanks for the help.
90FFyota Nov 21, 2005 09:16 PM
Any takers?
midiwall Nov 21, 2005 09:36 PM
Did you try dropping an email to them, or calling them? You could probably even use the 800 # for the order line and ask them.
http://lcengineering.com/
Elton Nov 22, 2005 12:25 AM
22r header will fit as i have one on my truck also do a search
bob200587 Nov 22, 2005 01:09 AM
I think you actually have to have a plug to use it with the 22r. It does have the spot for the O2 sensor, and I think thats the only difference.
Elton Nov 22, 2005 01:12 AM
i guess some come with spots for the o2 sensor mine didint have one just the one down by the cat
bob200587 Nov 22, 2005 01:18 AM
A guy I know has a 22r and his LC header came with the O2 sensor hole. It also came with a plug of sorts if you didn't have the fuel injected motor. I'd hope the things were consistent.
03_4x4Runner Nov 22, 2005 08:55 AM
like said above, just shoot them an e-mail or a call, they should be able to answer any questions you have.
Elton Nov 22, 2005 09:53 AM
yep just give them a call there really nice there
Fahrenheit 451 Nov 22, 2005 03:35 PM
The early headers came with the o2 bung in the #3 primary, but since this tended to cause issues with CELs getting thrown from inaccurate readings they changed over to locating it down just before the cat.
I have an old set that I hate for the noise, but they have given me good service otherwise. The newer versions are also a thicker gauge metal so they will be a bit quieter under the hood.
90FFyota Nov 22, 2005 03:39 PM
Thanks for all the help guys, I contacted LC today and my header should be here by Monday.
