YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Increased Fuel Capacity ? (https://www.yotatech.com/forums/f2/increased-fuel-capacity-83032/)
T-A-Z-M-A-N Apr 7, 2006 07:01 AM
I am trying to find a way that i can carry more fuel other than jerry cans. I want to either upgrade to a 120L gas tank or add a second reserve tank to get to 120L...if anyone has any ideas or information on how this can be done that would be great. Thanks.
BruceTS Apr 7, 2006 09:01 AM
before I decided to just relocate my fuel tank to where the spare tire is, I had planned on adding a second tank. I'd use a stock fuel pump assembly and wire a relay to turn on, pumping fuel to the main tank, when the low fuel indicator came on. Filling the tank was easy to figure out, the filler hard line has a bend in it, at this point I'd weld in a "Y", so when you can fuel up both tanks at the same time, this also help keeping them pressurized as well. I may still do a variant of this design, so I can will have a 30 galllon capacity.
WATRD Apr 7, 2006 09:20 AM
Perhaps you can get one of these to work without too much trouble. I have the Tacoma version and love it.
http://www.downeyoff-road.com/BodyCo...iaryTanks.html
ac808m Apr 18, 2006 07:33 AM
Rob,
Where did you put your filler neck @? I'd love to get one but I don't think I can afford the 4" drop to my spare w/o a lift.
Aaron
WATRD Apr 18, 2006 08:46 AM
The filler goes in the left, rear wheel well. You can see it in the inset of the this photo.
http://www.watrd.com/mods/images/auxfueltank.jpg
ac808m Apr 18, 2006 09:38 AM
;) I see
PO2SIMS Apr 18, 2006 11:03 AM
Downey talks about how to use the aux tank as a replacement for main tank. I think the 2nd gen 20 gallon aux tank would be a good relocating tank for 2nd and 3rd gens wanting to do a custom link setup.
