YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Icon upper control arms (https://www.yotatech.com/forums/f2/icon-upper-control-arms-264452/)
ARB1977 Jan 24, 2013 03:19 AM
Are these hard to install? Nothing needs to be pressed in the spindle? I'm debating on getting these vs other brands?
turbo8 Jan 24, 2013 11:44 AM
They are not too hard to install, you will have to press out the upper ball joint from the spindle and press in the adapter slug into the spindle.
you will have to move some stuff around the engine bay to get the upper arm bolts out.
ARB1977 Jan 24, 2013 12:55 PM
Thanks. Are there any tricks other than a press to remove and install the slug?
turbo8 Jan 25, 2013 11:46 AM
I used a modified pitman arm puller to press out the ball joint and to press in the slug.
ARB1977 Jan 25, 2013 12:44 PM
How did you modify the pitman arm puller to work?
turbo8 Jan 25, 2013 02:51 PM
ground it down some, bought it from autozone.
ARB1977 Jan 25, 2013 03:51 PM
Thanks.
