hub nut removal cv axel
havent been here for awhile but just bought a 98 4x4 tocoma and it needed a cv boot so started on it today and also it has manual lockout hubs, my problem is it has one of those 6 finger spindel nuts and i cant find a socket anywhere to get it off, need to repack the bearings but got to get that thing off, anyone know about these and where i can get that tool? and is it right hand thread , or left ?
I use a 36mm socket. I found them at Sears (Craftsman). I just put it in 4wd, and pop open the nut with a breaker bar.
thanks but this is not a standard hub nut it has 6 small slots cut in ,it takes a scocket that has 6 small studs that stick out about 1/16 inch or so. .
:/ Are you talking about the hub nut "cover" that is held on by the cotter pin? (blue in color)
Can you take a picture? Never heard of this before. |
i will try to put up a picture tommorow. thanks, it has lockouts already removerd them and the snap ring and washer then there this crazy nut moved it some with brass punch , but decied to try and find a socket. my manual is no help on this. eaither.
