How do coil overs relate to vehicle alignment?
This may be a dumb question...
I'm on the fence as to whether or not I’m going to install some new coil overs (probably SAWs) myself ('03 Tacoma). I found some pretty good, detailed instructions on the web and it doesn't seem that difficult. But while I am mechanically inclined, I really don’t do much auto work beyond fluids.
That said, it seems like a lot of people recommend getting an alignment after installing the new coil overs. Ok, fine...
I have no idea how vehicle alignment works at all. How badly can (or does) the alignment get out of whack when putting on new coil overs?
Or, what's the mechanical relationship between the coil over assembly and whatever controls vehicle alignment?
Just peering underneath it seems like the coil over assembly has two fixed points – 3 mounting bolts on top and 1 bolt on the lower shock eye. If the new shock assembly attaches to the same 2 fixed points, how does this relate to the alignment?
Thanks in advance for the clarification.
I'm no expert myself but the suspension indirectly affects the alignment. Just like how the tire affects the alignment, if the suspension is out of whack, it can affect the alignment as well
Therefore, whenever you do any suspension work, it is wise to get an alignment. Always good to be safe than sorry.
Re: How do coil overs relate to vehicle alignment?
Originally posted by newheeler
Thi
Thi
hope that clarifies.
Also there is a caster angle which I won't bother getting into, basically it's the angle the knuckle is making front to back with respect to the vertical. that ones really hard to explain without a good diagram
Re: Re: How do coil overs relate to vehicle alignment?
Originally posted by keisur
if the new assembly is longer or shorter than the current one then the alignment will be out of whack after the install of the new stuff. the alignment is basically adjusted by the two eccentric bolts on the lower a-arm (camber) and the inner tierod/outter tierod connection (toe). then the length of the coilover changes, the camber becomes negative (top of tire leaning in, indicative of a shorter coilover causing a lowering of the front end) or positive (top of tire leaning out, indicative of a longer coilover causing a lifting of the front end) and the toe may also get out of spec. like GT said, get an alignment, better so be safe, even if it feels ok. Also there is a caster angle which I won't bother getting into, basically it's the angle the knuckle is making front to back with respect to the vertical. that ones really hard to explain without a good diagram.
Re: Re: Re: How do coil overs relate to vehicle alignment?
Originally posted by waskillywabbit
I am very disappointed that there was no Free Body Diagram provided.
Vargntucson
07-04-2015 12:15 PM
