Best HID Immitation Bulbs
The best immitation HID bulbs out there are the ones I have. They are 90w low beam and 100w high beam. Stock and almost all immitation HID bulbs are 80/100w. I found mine on eBaY for $50, but there are a bunch of these immitation ones there that don't do much at all. Look for MotionR 6000K Xenon bulbs. Those are the brand I got. And when/if you get them, turn your headlights on after you have replaced only one. You will really be amazed. I was. So far I've had them in 7 months with no problems. I even accdentally got water in the headliht housing once when I was cleaing my engine, but they are still bright, white and running fine. A tip: it is imperative that you don't touch the glass part of the bulb because the xenon and krypton gasses inside are attracted to the oils from your fingers. If by accident you do end up touching them, clean them of with an alcohol pad or dip them in Isopropynol (rubbing alcohol) and wave them dry. If someone can teach me how to post a photo, I can show you the comparison between my bulbs and my mother's stock bulbs in her Land Cruiser. I'm not sure if they're on eBaY now, but if you ever see the name, jump on it.
Zach:eek2: |
