YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   help!!! problem on check engine light??? (https://www.yotatech.com/forums/f2/help-problem-check-engine-light-158413/)
siremacking Nov 4, 2008 05:46 PM
i got a toyota tacoma 96 model with 5vz engine. recently my check engine light turns on. i just change my fuel filter and change oil. what must i check for this check engine light to turn off.
i live here in the philippines.
scuba Nov 4, 2008 06:31 PM
try reseting the Ecu...(disconnecting the neg battery cable) for about 10 mins.
then see what happens...If it comes back on you going to need a scanner to see the actual problem
