Help mounting non stock fog lights to look stock 2001 4runner
My 2001 4 runner did not come with fog lights and I have purchased after market fog lights. I was wondering if any has experiencing in mounting fog lights in the stock cut outs in the bumper. I checked the tech section and did not see any information. Any help would be greatly appreciated.
Thanks |
check to see if the foglight kit u purchased comes with it's own mounting brackets. Most do.
I mounted some Hella driving lights on mine. I had to enlarge the holes in the bumper and fab up some custom brackets to mount them. I tried to get some shots of the brackets but it's a bit wet to be lying on the ground here. This is how they look from the front
http://i35.photobucket.com/albums/d1.../Foglights.jpg http://i35.photobucket.com/albums/d1...d/Foglight.jpg |
My lights fit in the opening but the issue is the brackets that come with the kit are small. They are designed to fit in small areas. If you get a chance I would like to see how you mounted them. I am in no rush to install these. Thanks.
Finally got some pics of the brackets and mounting location. I mounted the brackets to 2 bolts that attach the lower valance to the bumper, one above the turn signal and one at the corner. You can see the rusty nuts in this fuzzy pic
http://i35.photobucket.com/albums/d1...d/DSCN0116.jpg Here's some shots of the brackets with the light attached http://i35.photobucket.com/albums/d1...d/DSCN0113.jpg http://i35.photobucket.com/albums/d1...d/DSCN0114.jpg http://i35.photobucket.com/albums/d1...d/DSCN0115.jpg And here's one with the light installed on the truck http://i35.photobucket.com/albums/d1...d/DSCN0117.jpg One day I'll have to figure out how to post smaller pictures. Edit, now the pics are too small, I hate computers :bang: |
kool, looks like how I made mine. Used flat hurricane straps from the hardware, cut, fit and used some nuts bolts and washers.
Or you could put in some Piaas in the lower valence like I did....
Matt |
