YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Help with engine mounts!!! (https://www.yotatech.com/forums/f2/help-engine-mounts-105950/)
vrrodri Feb 1, 2007 04:07 PM
I tried replacing the engine mounts in my 99 2.7L taco, got one to fall in after 45 minutes of jacking up the engine and chassis. The driver side mount does not want to line up and I am only able to secure the main mounting bolt in the middle. I tried to lift the chassis several times but it will not budge. So the bolt holes on each side do not line up with the bracket coming from the engine. I even tried to rev the engine and drove it around the block to see if it would move into place but nothing. Any ideas???
