YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   HELP with brake light (https://www.yotatech.com/forums/f2/help-brake-light-32317/)
4runninstyle May 9, 2004 10:11 AM
My right rear brake light is out and i went to the auto parts store thinking I could just replace the bulb. Well i tried that and it still didnt work. So now i am thinking the wiring could be all messed up. I need help fast.
GRNTACO May 9, 2004 10:27 AM
Check and see if the ground came off. Does anything else work, blinker, tail, etc.?
4runninstyle May 9, 2004 10:36 AM
the blinker and tail both work just not the brake light. How would i check the ground?
GRNTACO May 9, 2004 10:41 AM
Not sure of the wiring on the 4runners. Follow the wires off the tail light, should be grounded to the frame somewhere.
