YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Head Gasket Question (https://www.yotatech.com/forums/f2/head-gasket-question-137691/)
RCFJ40 Feb 16, 2008 04:29 PM
Well I'm a noob to this forum and I have a tech question. Other than checking the dipstick for radiator fluid mixed in with the oil, is there another way to check for a blown head gasket or a leaking one on a 99 Toyota 4x4 with a 2.7L I4. Someone told me that if you take the radiator cap off and rev the engine, if coolant shoots out then you have a head gasket leak just wanted to see if that was true thanks for your replys.
Caffeine Feb 16, 2008 09:15 PM
I'd say that almost every engine will shoot coolant when you rev the engine. The only only obvious signs that I know of for a blown headgasket is exhaust that is white and smells kind of sweet. Coolant levels that drop, or oil in your coolant also are signs of course.
Adam F Feb 17, 2008 12:56 AM
You can buy a chemical test kit that checks for the presence of combustion gasses in your coolant.
85 PICKUP Feb 17, 2008 02:43 AM
Take it to a shop and have the engine pressure tested (I believe it is a cylinder leakdown test or something) Shouldnt be more than and hour of labor and worth it for peace of mind and salvaging your engine.
RCFJ40 Feb 17, 2008 06:54 AM
Great I'll go to the dealership and have them do the leakdown test thanks 85pickup and thank you to everyone who responded. If the gasket is leaking or blown I guess I'll have a good thread to post on the rebuild LOL.
keithguts Feb 17, 2008 08:09 AM
A dealership, you sure you want to do that?
MTL_4runner Feb 17, 2008 05:11 PM
Check your coolant hoses.....if they are very hard after the engine heats up, you could have a blown HG.
