gears/tires
ok, I have heard that the 5.71's were weak, didnt know why at first but i read that it is because the teeth on the pinion are shorter and shorter for each lower gear you go to and at 5.71 they are shorter to the point of weakness. but, wiht a huge lift, which I want, I would want to put some 37's maybe 38's under there, and I know with a 217:1 crawlbox I would push them with no problems off road, or even playing at hgiher speeds using the 4.70's in one case still no problem, but when running the 1:1 2WD high, 5.29's arent gonna push no 38's veruy easy will they. and I am for sure going to wait til I find a 5 speed now that I have been looking at all the mods, like the dual lever T case shifter, body lifts, dual T cases and stuff, none of these are auto tranny friendly, plus since the power is low.
anyways, If i carried a tool box with me like I always do, what all is necessary to install a R&P if I blew the 5.71 while on a trail, cuz they will for sure last on just everyday street driving correct? |
I have a friend with a '83 with 5.29's and 36" swampers, it gets around ok for what it is, i dont know what year/engine truck that you have but 38's should be "ok" with 5.29's, but wont be no race truck
I'm not even sure on this but I'm just throwing it out:
How about 4:10's? |
How about 4:10's? |
Originally Posted by keisur
:chairfall
I thought the 4:10 was a strong gear. |
The lowest that anyone goes who wheels it hard is 5.29's.
About the largest tire people go with that still drive to trails is a 37" radial, plus or minus. What this means is that you could run larger than 37's and you could run deeper than 5.29's, but there must be a reason that a lot of others have avoided that route. What rig is this going on? I have 33's with 3.0 and 5.29's on my 95 auto. I cannot imagine trying to get 38's up to road speed, especially because 38's likely mean a big, heavy, bias ply Swamper. Maybe on a lighter pre-1990 runner with a 5spd and better drivetrain you could push it a little more, but I really think it would be disappointing. If you don't have the rig yet, I would have a little patience about this. 35's will get you on and over a lot of trails plus be tolerable on the DD. |
Is it that bad?
they are but this guy is talking 38" tires.
The only reason I threw it out is because I know a guy who is running an 8" lift on his FORD with 38" yet running 4:10 gears. I asked if he planned to regear and he answered no, he was running fine with 4:10. I take it now that the guy doesn't know his stuff.
maybe the Fords are geared differently up front but his engine more than likely is pushing more horses which could make it easier. I wish the V6 4runners would push the 250 to 300 hp mark STOCK. that would be nice. |
If the Ford had a 460 or 351, it likely laughed at those tires on less they were 18" or whatever really wide Cepek's.
Yeah, 4.10's are stronger. No they will not make driving 38's on the road fun, and your clutch will hate you. Scott Ellinger ran 4.10's with a 22RE turning 44's on the first Mantis. He needed to start moving with one case in low. Probably not the sort of thing I would want to do on a DD. |
Originally Posted by Flygtenstein
Scott Ellinger ran 4.10's with a 22RE turning 44's on the first Mantis. He needed to start moving with one case in lo. Probably not the sort of thing I would want to do on a DD.
Originally Posted by toy283
It's all a matter of torque. If you increase the tire size, you increase the amount of torque needed. This can be accomplished in two ways: regear to lower gears or increase available torque from the engine. A V8 is gonna have way more torque than a 4 cylinder. FWIW, I run 38's with 4.10 gears and 400ft-lbs torque at the crank. For highway driving, I have considered gearing up to 3.90's but the cost isn't justifiable.
If this makes a difference, a 7.3 liter turbo charged diesel was pushing the 38" with 4:10s plus a monster exhaust all the way out.
yeahs, that powerstroke is a real beast, my aunt pulls whats gotta be a 20-25 foot horsetrailer with 2 horses behind the F350 crew cab and its like it isnt behind it, well you do know its behind the truck but it had no problem at all cruising with that railer behind it.
and about the gears, this is going to be my daily driver, and it is going to be a 2nd gen runner, 5 speed, if I can get enough out of my 2 cars for sale I am going to go over to my dads friends house and putting some leafs in the rear and SAS'ing the rig. also I wanna throw some x.xx's in and detroit ez lockers F&R, and if I wanna put in the crawlbox with stokc gears in one and 4.70's in the other. I will probably go wiht the 35's at first then I guess since I will wanna go offroad wiht it alot, 5.29's are strong enough though right? cuz 4.88's pushing 35's on the highway sounds like it wouldnt be no fun, and then if I did go to 38's sometime, then wow that would suck. I wanna go ahead and do the SAS/rear leaf first though because I got a friend that my dad knows and helps out alot so Im sure hed help me, and he is really good at working with metal. Plus the price of the front gears/front lift and rear lift, would be better used for some of the funding for the SAS/rear leaf so that I dont have to sell it all when I decide to change, plus its alot easier to get more lift with leafs. shackles/blocks/different leafs. cuz the front gears are different for the IFS and the SA, right? |
Originally Posted by superjoe83
the ifs front uses a 7.5" ring gear, and, the normal toy (non tacoma) solid axle is a 8" ring gear, the 3rd members are interchangeable between the front and rear on 8" solid axles. (someone correct me if im wrong)
Nope. You nailed it. :bigok:
| All times are GMT -8. The time now is 06:45 AM. |
