Gear Ratio
Ok, I found this link! http://www.sonoransteel.com/Toyota_axle_codes.html
But its still kinda confusing. My model is #VZN185L-GKPZKA Now it gives you two options..one with 4.10 & 4.30 w/265/70/16. So if my 4Runner comes with 265/70/16..I have 4.30? |
There is an axle code on the door jamb vin sticker.at the bottom you should see A/TM. The first 4 Letters & numbers are your axle code. A03A for example.If you get that code you can get your stock axle ratio .What part of PA are from?
Shubey |
Im from williamsport. Ok, A03A is my axle code , so whats the ratio?
Should be a 4.10.I'd have to check my notes at work tomorrow to be sure.
Shubey |
Ya, 4.10 it is....http://www.brian894x4.com/Gearratiosanddiffs.html
| All times are GMT -8. The time now is 01:24 AM. |
