YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Front diff isolator bushings? (https://www.yotatech.com/forums/f2/front-diff-isolator-bushings-315248/)
Ekaiiscool Mar 27, 2022 03:15 PM
Hey, I'm just dropping diff an inch, noticed where the diff support mounts to the sub frame seems a bit rediculous... Almost looks like it's missing a peice to flatten everything out???
Is there a little rubber spacer that sits on top of the diff support bushing??
Pics to follow.
Ekaiiscool Mar 27, 2022 03:39 PM
Very strange. See below:
https://cimg1.ibsrv.net/gimg/www.yot...88e2e74946.jpg
Raised lip - missing isolator?
https://cimg2.ibsrv.net/gimg/www.yot...d3ff318edb.jpg
Looks a bit dumb.
aowRS Apr 12, 2022 04:52 AM
Better pics would help...
Andreas
fierohink Apr 12, 2022 06:06 AM
I'm pretty sure that is correct. The isolator is the rubber hanging out of the bottom. The center sleeve mates hard against the frame and is the inner barrel the bolt rides in. Then the bushing isolates between that inner sleeve and the big hole of the diff. If you put a bushing between that middle tube and the frame you wouldn't have a solid foundation to anchor the bushing between the diff and the mount.
Ekaiiscool May 5, 2022 08:42 PM
So, it turns out there is supposed to be a bushing there, but it's been discontinued and there are 0 left in the world. No aftermarket option either.
https://cimg5.ibsrv.net/gimg/www.yot...1c25954ad3.jpg
41654A is literally just a steel washer (which I have), 41653B is what I am after, both are called "diff bushing stopper" in toyota literature. According to my vin, I need 4165335010
https://cimg9.ibsrv.net/gimg/www.yot...1f26603cb4.png
https://cimg3.ibsrv.net/gimg/www.yot...0deffefc34.png
aowRS May 6, 2022 02:37 AM
DuroBumps
Andreas
Ekaiiscool May 6, 2022 11:14 AM
Thanks. The only problem with the durobumps (which have this peice built in) is I cant be assed to put in the work to get the old mounts out of the metal bracket.....
However, someone else discovered the part was at some point superceded by pn 416530c010
Stealership got 2 out of kentucky on the way, so ez fix.
