YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Front Diff Fill Plug Stripped!!! :( (https://www.yotatech.com/forums/f2/front-diff-fill-plug-stripped-137757/)
OSU4Runner Feb 17, 2008 03:14 PM
Ok guys, I changed all the fluids today, and when I got to the front diff, I was faced with the infamous hex plug. The fill plug was already pretty tore up, but I cleaned it out good and gave it a shot with the 10mm hex. To make a long story short, its now completely stripped out :flush: .....so I just left the drain plug alone. So what are my options? Should I take it to the dealership to have it removed with a tap and dye? Don't have a set myself, and I don't wanna deal with the headache. I hate the front plugs!!!!! Will a 24mm 6 point plug fit on the front diff? I'd really like to get rid of them. :saw:
MTL_4runner Feb 17, 2008 05:18 PM
Just let a garage deal with that if it is that stripped.
toytech76 Feb 17, 2008 05:29 PM
if its just the inside part thats stripped, go get a air chisel and make a notch in the side, then hit it counter clockwise to spin it out
YodaPala Feb 17, 2008 05:33 PM
Hells yeah, that always works for me!
OSU4Runner Feb 17, 2008 05:41 PM
Ya the only problem is I don't have an air chisel!!
Skrillah Feb 17, 2008 05:55 PM
x2 on let it be someone elses headache...
If you were using a 10mm hex, that may have been your problem, i thought they were 12mm?? I can't remember and I'd have to go look but I know I had to buy a special one from sears cause they didn't come in the sets...
OSU4Runner Feb 17, 2008 05:57 PM
I think the early 3rd gens were 12mm, thats what I've heard. 2000 and on the were 10mm.
Elton Feb 17, 2008 05:57 PM
yea i tried to change my front diff fuild got that 10mm hex in there good and tight and tried it with breaker bar well its pretty much trashed no way ur getting it off i really wish they would of use a bolt like the rear why they didint not sure
OSU4Runner Feb 17, 2008 05:58 PM
Anyone know if the 24mm plugs in the TC and rear diff will fit the front diff? I'd really like to get rid of these hex plugs!
Elton Feb 17, 2008 06:01 PM
yea that hex plug wrose idea ever my freinds chevy is pretty cool u just stick the 3/8'' ratchet in there
RunnerUp Feb 17, 2008 06:01 PM
i dont believe they will, i stripped mine out also so i took it to toyota and they said negative... not that that makes it true, but its what they said
bwhyit Feb 17, 2008 06:03 PM
You don't have to have an air chisel. Just use a chisel and a hammer. I had the same problem and it worded for me.
digitalracer Feb 17, 2008 06:07 PM
I welded a big fat nut to mine because the same thing happened to me . I just found one that was about the same size as the drain plug and welded it on. Works like a champ and for all intents and purposes it now has a 6 point socket head on it...just another option for you, hope it helps.
One_96TR4 Feb 17, 2008 10:00 PM
Yes the rear plug WILL fit. I stripped my rear plug and had to order a new one. When I went to pick it up it was a front plug. I couldn't afford to have my truck down for another day so I put it on. Needless to say I'll be ordering a new one and swapping it out once it warms up. Good Luck.
dirtoyboy Feb 18, 2008 06:17 AM
I cant believe all these guys are saying to take it somewhere!
:think:
air chisel would be the best...
try some extraction sockets like these
http://img.auctiva.com/imgdata/3/6/5...1604580_tp.jpg
welding to the plug would be next..
If you dont have an air chisel you can also use a chisel and BFH
bwhyit Feb 18, 2008 06:44 AM
Don't know about all the years but I've got a 98 and the fill plug is aluminum. Don't think trying to weld it is a good idea.
MTL_4runner Feb 18, 2008 06:50 AM
Someone must have replaced it then.
Most of them are cad plated steel.
GrillmasterP Feb 18, 2008 07:05 AM
:think:
Extraction kit like that won't work on the Toy Front diff fill or drain plug-
Its a flush head with a hex recess.
http://www.marlincrawler.com/images/plug&socket_500.jpg
We welded a lug nut to my bro's front diff drain plug after I broke 2 3/8" drive craftsman 10 hex bit sockets - (I recommend 1/2" drive and impact)
Unfortunately, for the OP, the fill plug is harder to reach than the drain plug.
OSU4Runner Feb 18, 2008 07:23 AM
I'll probably just take it to a shop. There isn't much room in front of the fill plug to work with a chisel and BFH
MTL_4runner Feb 18, 2008 08:36 AM
Smart man........it's not worth the agravation.
They'll probably just hammer in a larger hex socket and zip it out with an impact gun anyway.
