Foglamps for 2000 4R
so, since some 4Rs came stock with foglamps, there are holes in the bumpers for them. and for the 4Rs that didnt come with them, they were covered with little plugs i guess youd call them. Well, for the 4th time in its life, my 4R has had its plugs stolen.
So, where can I get the OE type foglamps that fit in there? Ive tried aftermarket ones that look like theyll fit but they dont. I dont want to go to the dealer because theyll rape me. I need the lamps, relay, harnesses, and switch, and some other junk. Apparently the SR5 is already semi-prewired for fog-lamps... |
Check this site out... these should work for you...http://www.performanceproducts.com/P...producttype=20 :banger:
I bought a set for my 2000 SR5 from http://www.conicellitoyota.com/ 2 years ago. At that time, they were cheaper than Performance Products. They're not difficult to install but do require that you remove the steering column cover to tap into the wiring (IF you intend to follow the directions). If you're looking for driving lamps, then find more "plugs" (I'll send you mine) and install some other lamps. The OEM fog lights are decent for inclement weather with it's short, wide beam pattern.
BTW, why the heck would anyone steal those plugs? Are you sure someone isn't screwing with you? |
Thanks for the links guys.
I have no clue why someone would steal the plugs. The first time it happened, I thought they just fell out, but then i realized both of them were gone, then 2 month later the same thing (this was about 2 years ago)...2 months ago, it happened again, anf on tuesday, my friend (I was following him) asked me what the holes in my bumper before, that hed never seen them. I was ferious...and If I put fog lamps in there and round the heads of the bolts once theyre gone, Ill never have holes in my bumper again.... |
