YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Flowmaster (https://www.yotatech.com/forums/f2/flowmaster-51907/)
iGGz Feb 15, 2005 11:28 AM
Flowmaster
Well I called a local exhaust company.. and asked how much it would be for them to put in a flowmaster muffler... high-flow cat... and then the 2.5 tubing right from the headers to the end and they said around $500
Haha sounds pretty damn pricey to me
rimpainter.com Feb 15, 2005 11:34 AM
That sounds about right to me.
iGGz Feb 15, 2005 11:51 AM
Hmm a flowmaster muffler is about $80-90...
How much is a high-flow cat?
Is this a good high-flow?
http://www.jcwhitney.com/autoparts/P...odelId-5001801
And what do you want for the high-flow? A two way or a three way?
So just the muffler and the high-flow are about $210...
Is the piping pretty expensive?
I would purchase the headers somewhere else...
Ian
rimpainter.com Feb 15, 2005 12:00 PM
Is your stock cat defective? If not then you are not going to see a much from a high-flow cat. I would get a Carsound cat from ebay if you need one. I got mine for $57 shipped. As for the muffler, you can get a magnaflow or similar off ebay for a good deal too. So, you are at about $125. Custom piping runs about $250 or so. So, you are right around $400 by getting all that stuff yourself and having it installed.
I would not exceed 2.25" if you have the 4cyl BTW.
Keep in mind that most exhaust shops will not weld on stuff you bring them. I think its pretty lame myself, but that is what I have found. You will need to call around.
If I was you, I would get a magnaflow or similar muffler welded in place of the stock muffler and see how you like it. That right there should be under $100.
jtm994 Feb 15, 2005 12:02 PM
i got mine done for $235 at a local shop here in ga
iGGz Feb 15, 2005 12:04 PM
Does flowmaster not sound as good with an auto 4cyl?
Why do you recommend the magnaflow?
Thanks Ian
rimpainter.com Feb 15, 2005 12:25 PM
I just named magnaflow because they are a reputable brand. Flowmaster is cool too. Whatever floats your boat (or rig).
Remember, not too big on the piping.
