williemon |
02-02-2004 07:48 AM |
I had 2 just strip out on me a couple years ago. They were toward the back of the head. I went for a full year before I could do the repair. I pulled the exhaust manifold and down pipe out as one unit, cleaned and sandpapered both the head and manifold, drilled out the stripped stud holes, cleaned out the shavings and installed helicoils and put everything back together with a new gasket. I also coated the gasket with a copper exhaust gasket spray. I torqued them down in proper sequence but still pulled another stud out. I went ahead and drilled that hole while the manifold was still bolted on. Installed the helicoil and stud, then tightened it down too. Once all was done It has stayed true. I drive 40 miles to and from work, and anywhere from 2 to 10 miles of on and off around town driveing everyday, and it has stayed together for a year now.
Someone also mentioned that you could just retap and use an american head stud i think, but i went the helicoil route. If you do a search for exhaust studs or helicoil, you may get some more info.
