ESC1 Hookup...not working...?
Ok...i recently installed teh esc1 in my taco and the O2 wire that im connected to is the right one for sure so i ruled that out but the problem is...well it doesn't do what is is supposed to...i did not connect the wires to the second o2 sensor behind cat because it said something about not having to to...but i know the esc1 is getting enough PSI from boost port because my gauge which its t'ed with is reading all the way up to 6psi....there could be a leak at the t'e as the tubing fo rthe esc1 is smaller then the type of t'e i was using but i duct taped the hell out of it to prevent loss...that is a temp fix by the way =]....anyway im sure the tape will keep at least 2-3psi in to keep the esc1 activated so im not sure that ould be problem....
now do i need to have the second o2 sensor hooked up as well or will that not matter? 96 taco v6 smt6 370 injectors yadda yadda.... THANKS! |
Good luck man! I would ask gadget@gadgetonline.com, because he's the master of all this stuff.
Chris |
