YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   engine sputters after warm up (https://www.yotatech.com/forums/f2/engine-sputters-after-warm-up-255436/)
Brian Bunch Jun 26, 2012 12:17 PM
I got a 2000 4runner 3.4 ,runs good when cold but after driving and warms up it starts sputtering out of the exaust,the same when it is warm and starting it sputters,it did this about 2 months ago and I replaced the plugs and wires and it went away and now is back,any idea's on the problem will help
luishernandez2000 Aug 30, 2024 03:13 AM
Same problem
Im having the same problem how did you fix it?
Malcolm99 Sep 8, 2024 06:24 AM
injector failed, they are usually intermittent, but fail after a heat soaking. swap coil and wires to make sure, then order all 3 injectors for the side that is failing, usually #4 misfire for some reason on a 99+
