Engine Oil for 3.4 v6
How many quarts are everyone puttin in their 3.4 4x4 tacoma engine WITH oil filter change. Mine takes a little over 5.5 quarts. What does everyone else use? also it says on the fill cap SAE - 5w-30 oil....but i use 10w-30 oil...is this ok? I live in south CA so it dosent see much freezing weather... thanks!
p.s i use castrol non synthetic gtx oil at 148k miles the engine dosent drip a drop or consume anything noticably... |
5.5 qts, 5-30 here. I think you could safely go down to 5-30.
i have a 2000 v6 4x4, and i use 5w-30 regular dino oil here in mid cal..
my rig usually takes about 6 quarts with oil change. russell |
96 runner sr5 0w30 amsoil series 2000, running just fine!!::)
I use about 5.5 quarts with a filter change.
I doubt 10w30 will harm your engine, but 5w30 would be optimal. Might give you a slight boost in fuel economy too. |
A tad over 5.5 qts w/filter change (when don't you change the filter when doing an oil change?!?!?!) on my '00 V6 3.4L.
Anyone else use 10w-30 in Cali? |
I put in 6 quarts, after the filter has filled up, the oil level is just below the full mark.
Originally Posted by InFlames
I was stating that I always change the oil filter with a Toyota oil filter every oil change. Some people go 10K on the same oil filter...i wouldnt!
Anyone else use 10w-30 in Cali? I use 5-30 but I go up to the snow a lot....but I have friends who are desert bunnies and some of them run 10w-30 |
I use 5W-30 in mine because that is what the manual says is preferred and will work for all climates. 10W-30 is recommended for temps above 0 degrees.
I use 0w-20 oil. It's recommended for toyota's. And I have a 99 tacoma 3.4L engine. And mine holds 6 qts.
Originally Posted by Jsweatt1987
(Post 52207480)
(Post 52207480)
Originally Posted by hotlavaaaa
(Post 52207483)
Bumping a ten year old thread to add bad advice. Interesting. :think:
(Post 52207480)
The TSB can be found here: http://www.matrixowners.com/tsb/TS-EG018-06.pdf |
Again, a 10 year old thread bump by a misinformed soul. I think the important thing is just change your oil every now and then :roll:
I think once in awhile is much better then now and then!!:wrench:
Originally Posted by SLC Punk
(Post 433625)
Originally Posted by socalbobby
(Post 52390903)
K&N for life
