YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   engine light (https://www.yotatech.com/forums/f2/engine-light-142687/)
kenstoy Apr 13, 2008 06:37 PM
engine light
hey looking for some help or suggestions on my 99 taco engine light 3.4.me and a friend put it on a computer and it read a code bank 1 sensor 2 code po136 . im not to sure im still new with this . anyone with some ideas or salutions i would much appreciate it . i do notice a drop in fuel mpg and a lower ruff idle but not all the time. HELP thanks Ken. also where sensors might be located. or any sites with info.thanks
jason191918 Apr 13, 2008 06:47 PM
http://www.ncttora.com/fsm/2000/Repa...ngine/dtcc.pdf
Looks like the O2...
kenstoy Apr 14, 2008 12:25 PM
thanks for the info do you know if the o2 is before the cat or after the cat.and where i can buy one.thanks ken
jason191918 Apr 14, 2008 02:20 PM
On mine it is before cat, but yours is gonna be different. Just follow the exhaust. You can get one just about anywhere. And when you are buying one ask them.
warriors_03 Apr 14, 2008 03:06 PM
3rd gen the a/f is before the cat, and 02 is after the cat.
mastacox Apr 14, 2008 03:11 PM
All oxygen sensors used for adjusting fuel mixture will be before the catalytic converter. Some vehicles have an additional oxygen sensor after the cat, but it is used to confirm the cat is working, not to adjust fuel.
kenstoy Apr 14, 2008 05:53 PM
thank you all for the great info.you all are a big help.i will post when i get done.thanks again ken
Ohio4R Apr 15, 2008 12:54 PM
Only california 4runners use A/F sensors all other states use O2 sensors. And it should be after the Cat.
