YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Engine bog down / power loss (https://www.yotatech.com/forums/f2/engine-bog-down-power-loss-290483/)
TACOJO Aug 18, 2015 05:16 PM
Hello. I'm new to this site. This is my first post. Sorry it is a long post,but it's been a long running issue. : 2002 DLX 2.4L std trans. I'm positive at least one of you here has the sme problem with your truck. *** Bogging down,power loss,rough idle,terrible mpg. I have replaced the following : injectors,coils,plugs,o2 sensor,A/F ratio sensor,both cats,coolant temp sensor,MAF sensor,TPS,cam and crank sensors,fuel pump,filter,fuel pressure reg.,idle control valve. Pressure test fuel system ( 40 psi ) smoke test,no vac leaks,no overheating,no fluid leaks,no smoke out of tailpipe. I've even replaced motor ( complete ) and it still has the above symptoms. Any ideas ? I'm thinking it may be electrical/ fuel issue. It does feel like its starving for fuel,and when I let go of acc pedal,it bogs down like it has a jake brake and makes a wooo sound. At my wits end ! I know this is a common Toyota problem,especially high mileage vehicles. I've search all over but no one seems to be able to pinpoint the problem. thx for any help:eeek::pop: *** all replacement parts are factory or Denso ***
Chasityk Aug 28, 2015 08:11 PM
I had something happen to me that I'm trying to figure out now too, I got stuck on the highway after I lost all power in my 4 runner. I went ahead and was turning on the highway starting losing power my battery light came on and then the car died. I went and got a new battery didn't fix the issue and now I am not knowing what to look for now. I was told it could be the relay fuse for the starter but not sure how to figure out if that is what it is.
wyoming9 Aug 29, 2015 01:20 AM
Neither of you had the MIL trip ??
If the MIL has not tripped I would think long and hard about trying another ECM.
Any more I keep a spare just for testing!!!
To the OP have you done all this work or had it done?/
If your paying your putting a bunch of kids through collage !!!!
All these parts you replaced tested as bad ??Then they were replaced with new parts out of the box??:wrench:
When the pump was changed what did the tank look like ??
Crushed or kinked fuel line .
Chasityk Aug 29, 2015 07:55 PM
I have not bought a new starter relay I was wondering if that could be a issue to cause what happened to me. But I did get a new battery and that didn't do anything but the lights come on just won't start for me.
AZ_98_4Runner Sep 15, 2015 06:40 AM
Did you check the PCV valve?
Do you have oil in the intake hose between the air cleaner, and the throttle body?
TACOJO Sep 22, 2015 04:32 PM
It sounds like possibly an alternator issue. If it's driveable,you can try one of the larger auto parts chain stores. they should be able to test the alternator / starter systems for free. you need to find out the voltage the system is putting out. It should be 14.2 volts . If not,may be the alternator,since you've already installed a new battery. I hope this helps.
TACOJO Sep 22, 2015 04:40 PM
I have replaced the pcv valve. No oil between air filter housing and T/B either. Everyhing has been replaced / checked / re-checked. No vacuum leaks,etc. No codes / no check engine light. To me,it's an electrical issue,short to ground and it's affecting the throttle. But TPS checks ok. But it has to be electrical problem in T/B circuit. This is cable controlled throttle,not the drive by wire on 2003 and up models,which I know have the same symptoms.
TACOJO Sep 22, 2015 05:06 PM
I've done some of the work on it and mechanics have done some also. No kinked fuel lines,no obstructed lines,no vacuum leaks, . Fuel tank inside is crystal clear,not one speck of dirt. Four fuel filters in 5 years. New pressure regulator. Everything new. The issue is not mechanical. It is electrical affecting the TPS circuit. But the mechanics are stumped because no codes/no check engine light. I know my truck,I drive it for a living, and the problem is at TPS circuit. But since I drive / push / pull my truck during the week,I have not been able to leave it at an auto/electrical shop for an extended amount of time. I will bet my left shoe its TPS related. Hard to find a good mechanic that will tackle this problem. They are scared because no codes/cel . Over 65 mechanics have checked my truck since this problem started. Vast majority have ˟˟˟˟ for brains. This has been my experience. IT IS AN Electrical issue . common to Toyota vehicles.
mt4runner99 Nov 27, 2015 05:26 PM
I have the same problem and have found out that it's a short somewhere. Just can't find where! Try unplugging fuses and driving it to see if it runs better. If I pull the fuse for the dome lights it seems to run just fine but then I have a lot of electrical things not working. On my 96 4runner it's the dome light fuse, and I can't find any wiring schematics for it, and wiring is a foreign language to me.
