Energy suspension F+R endlink part number
Anyone know the part numbers for the ES endlink bushings for the front and rear of a 3rd gen 4RNR?
i posted them up a while ago. try a search for energy suspension
that thread doesnt have the end link numbers though. It has the sway bar bushings themselves (which i do have). it has a link at the end to summit racing but not to a specifc part. thanks for the help and if you know the numbers it would be apprecited. ive searched and searched but just cant seem to find them.
9.8105 --does this number seem right?
what type of grease do you use to lube up the bushings as you put them on then through the fitting? any preferences?
anyone know if those are the right numbers? id=3/8, nipple od=11/16 and od = 1 1/8?
i just used some wheel bearing grease. Make sure its waterproof
cool thanks.. so i finally found a thread with the end link numbers and it is 9.8105. would these be the same in the rear as well?
i think its a 1' in the front and a 3/4in in the rear..or vice versa
for the end links...just check your stock front and rear...if they are the same, then the ES should be the same
any idea why it is suggested in that one writeup to point the split of the bushings to the front?
ya i havent cheched the stock set up yet,,and im goin to do it since that what was said..the unedumacted response was just as good to know that someone else did it like that.. how was the mod itself? pain in the a' or not bad
