Elocker Cable Conversion
So my elocker motor fried so I didn't want to pony up the $$$$$$ to get a new or used motor, they are rare and expensive. So I went ahead and converted it to cable.
So Blair (knoxtaco) and I used a bicycle stem shifter to rotate some welded on bolts to the elocker motor shaft. I had to cut my t-case shifter and move it over an inch or so so the shifter could clear the bicycle shifter. We routed the cables right with the e-brake cable and dropped it down right on top of the motor. Blair fabricated a little bolt on plate for the barrel adjusters to mount to. Here are some pics of the conversion. http://i150.photobucket.com/albums/s.../c-locker2.jpg http://i150.photobucket.com/albums/s...r/IMG_3823.jpg http://i150.photobucket.com/albums/s...r/IMG_3822.jpg http://i150.photobucket.com/albums/s...r/IMG_3827.jpg http://i150.photobucket.com/albums/s...r/IMG_3826.jpg http://i150.photobucket.com/albums/s...r/IMG_3828.jpg http://i150.photobucket.com/albums/s...r/IMG_3829.jpg We cut up the side of the motor so we could adjust and attach the cables properly http://i150.photobucket.com/albums/s.../c-locker1.jpg http://i150.photobucket.com/albums/s.../c-locker2.jpg Here's the shifter http://i150.photobucket.com/albums/s.../c-locker3.jpg |
So one of those little paddle things is engage and the other is disengage ?
Looks kool.. How much slack is there for flex though ? :dj: |
Originally Posted by scuba
(Post 51205994)
Looks kool.. How much slack is there for flex though ? :dj: We did it on a lift at full droop and it also has more flex in it above that. |
thats a high tech redneck there!:hillbill: serious ya gotta let me know how that holds up, during the torchure testing that you do!
Clever, hope it holds up!!!!!!!!!!
I've seen a similar fix done except they used a vacuum driven actuator mounted on the diff. and ran vacuum lines up to the engine and used a pair of junkyard EGR valve solenoids to actuate it.
You might want to replace those cheap plastic levers with some aluminum shifters. The ones you have WILL break! Trust me, I speak with 20+ years in the bicycle industry.
x2. dont slamb those levers...will create a moment those can't handle...
Originally Posted by DIHOWARD
(Post 51206134)
Originally Posted by KrashDH
(Post 51206228)
I know, and I can't slam them. The elocker won't engage if you slam them, you have to gently twist them both at the same time while turning to get them to engage. Basically the same thing you have to do with the elocker, minus flipping to levers. |
nice work.. whats that shifter from. never seen one like that
Originally Posted by akaphilly
(Post 51206259)
Well wheeled it today, c-locker locked and unlocked perfectly. Great not having to get out of the truck and use ascrew driver to lock it. Great day of wheeling, broke a cv, and saw a comanche get destroyed :D http://photos-b.ak.fbcdn.net/hphotos..._2138414_n.jpg |
Nice :great:
:rockin:looks like you might have a new avatar! might have to keep that in mind, if I ever get to step up to an e-locker.
why the hell did you take that approach to that particular part of the trail..from my point of view(which is obviously limited because im not there in person) it looks like you would have been better off NOT going up that embankment?????
i can just see your rig coming down on that pass. front tire and flipping....LOL:ignore: |
Originally Posted by camo31"10.50"
(Post 51257625)
i can just see your rig coming down on that pass. front tire and flipping....LOL:ignore: Same spot... http://i45.photobucket.com/albums/f8...0614091058.jpg Later on... http://i199.photobucket.com/albums/a...9/IMG_0156.jpg http://i199.photobucket.com/albums/a...9/IMG_0166.jpg |
| All times are GMT -8. The time now is 01:04 AM. |
