elocker
hey, I was looking on www.carparts.com for a diff lock, and found one a few months ago, but now I can't find what section to look under for them on the web site. I dont want the whole axle assembly and I dont want the whole differentail housing, so what do I want to find it under? Also, whats the deal with the lockers with 4.11 and 4.56 ratios? Does this mean they already have gears so you dont need to buy some, or does it mean they are just setup for that ratio? Thanks a lot!
First - make sure your at the right site. It's www.car-part.com not what you typed above.
2nd - look under "carrier" for "differential" 3rd - if it says 4.10 or 4.56 gears then it has to have those gears in it already. John |
sweet! Thanks! So i guess you dont need to spend the extra 400 or so for gears then!
Originally posted by MellamoPOUND sweet! Thanks! So i guess you dont need to spend the extra 400 or so for gears then! John |
| All times are GMT -8. The time now is 01:04 AM. |
