Electrical Problems!
I believe this is my first post on here since I bought my 98' Limited 4x4 4Runner 2 years ago. I am in a bit of a situation and not sure where else to turn. I grabbed a 2000 4Runner center console and cup holders to upgrade from my floppy radio bezel, climate control blocking ones. I installed the pieces and that went smoothly. When I went to start up the 4Runner, I have no power to any of my accessories, I cannot shift out of park, and my instrument cluster will only light up the airbag light and the battery light. The airbag light will go out like it should, but the battery light stays on. Now, ALL I did during the install was cut the tape off the harness for the back window and the ECT button. I checked already and did not cut into any wires and I was careful when working with them. I also relocated the RS3000 alarm sensor and light over towards the driver vent/ fog light switch area. I am pretty mechanically inclined and am taking classes to become an automotive technician. Sadly, I do not have access to my school's repair software and cannot get a wiring diagram. by accessories, I mean I have no power to anything inside the car besides power locks and headlights. I cannot turn the radio, climate control, windows (cabin or rear window or sunroof), or wipers or turn signals. I thought maybe I blew a fuse and I have checked them all as well as thought maybe the fuse panel "30A Power" maxi fuse may have blown. I replaced it to no avail. I also took my DVOM to the battery with the 4Runner running and it does not seem to be charging. I doubt it is alternator related as too many other items are messed up. Any ideas or help will be greatly appreciated as it is my daily driver!
there is no reason to replace a fuse because it "may have blown" when you have a DVOM. check all of them for power being supplied to them and continuity through them (or power on both sides).
Originally Posted by akwheeler
(Post 52398164)
No worry, I fixed it anyways. I'm no sure what the issue was, but I put everything back to where it was and it started up normal. Weird electrical Gremlins. |
First things first, do you still have your old parts? If so, restore to original and try to figure out what went wrong. If you restore to original and still have the issues then we can look at the wiring you disturbed or circuits that aren’t getting power. PM me an email addrsss because I think I have your EOD |
Originally Posted by richeaus
(Post 52398153)
... took my DVOM to the battery with the 4Runner running and it does not seem to be charging...
(Post 52398165)
...Weird electrical Gremlins...
